Making dimensions EQUAL = whilst in a sketch
null_null3941null_null3941 Member Posts: 17
When in a sketch, it would be great if we could make dimensions equal so the dimensions change together when I make a dimensional change.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 466
    Yeah, Onshape doesn't do dimension relations.  But you can make a variable on the fly.
    Or you can use constraints.
  • Urs_Egger_REACTUrs_Egger_REACT Member Posts: 100 PRO
    does already an enhancement request exist?
  • steve_shubinsteve_shubin Member Posts: 1,098 ✭✭✭✭
    edited August 2024
    Maybe this would work for you.
    Using the EQUALS CONSTRAINT
    The darker lined dimension in the upper rectangle is DRIVING the gray lined dimension in the lower rectangle
    ALSO, all lines on the upper rectangle have the EQUALS constraint applied
    Whereas in the lower rectangle, only the right most line has the EQUALS constraint applied
