Custom Feature: Gridfinity Bin & Base Generators
I just wanted to share the two generators I've written:
https://cad.onshape.com/documents/f307f8af01083b99b55bbcf9/w/e62d7ab7a660a796bb9461a7/e/10837cead0dddf47a9b60a3b
https://cad.onshape.com/documents/f307f8af01083b99b55bbcf9/w/e62d7ab7a660a796bb9461a7/e/6f4023e4bb25eda38c5e4f2d
cheers!
cheers!
13
A dovetail feature for the base would be great!
Pocket style slots for magnets for bins would be a nice thing to have
Looks great! Thank you for sharing. Do you plan on expanding features, or do you take feature requests/suggestions?
I have really enjoyed this generator so far! But I am curious why the generator automatically adds a profile at the back of the base when you select to add a filler space. It would be nice to keep it square all around and only add a space/profile/etc when they are defined.
I noticed the base filler will create smaller slots on the edge they are added too. Is there a way to also create smaller bin bottom connectors to fit those filler slots? I have a setup that can't fully fit another 42mm section on the edge.
Just to clarify if I add say 30mm of filler on the left it leaves a new empty base slot. I want to create a bin that can fill that 30mm portion as well.
Much thanks to anyone that has any ideas.
Great tool! Thank you for making and sharing. You have made my life much easier
This is a great piece of work which has saved me hours in creating my own designs!
I wanted to bring to your attention some observations when I checked out the unofficial "specification" at the link: Gridfinity | The modular, open-source grid storage system for your workshop. I don't know if I am missing something but it looks like your bin base and stacking lip are ever so slightly different from that document. I've highlighted the dimensions which look out to me in the sketch below, which shows a cross section of a base below a bin with stacking lip below another bin. Specifically:
a) dimension of the 2.4mm wide face of the bin bottom vs 2.1mm in the "spec"
b) clearance between bin bottom and base is a little larger than the "spec", 0.427mm vs 0.25 (technically I don't think the 0.25 of the "spec" is geometrically possible anyway)
c) the slope of the stacking lip isn't 45 degrees.
I reckon these differences are well inside the printing error of most 3d printers anyway, but I thought it would be useful to run this past you in case there is an issue here. As an engineering document, we might as well be accurate, in case it finds application in more precise manufacturing processes.
This is really cool.
I can see in the example shape there is a half bin, but the configuration doesn't allow for half bins…
Is there a way to achieve that using the offsets somehow?
Thanks!
Hi Sheishin, thanks for this tool, I am using V8 now. Perhaps a bug, but it seem to crash when I try to add labels or scoops to partioned bins like this one show below. I'm trying to add labels and scoops on the x axis of these bins:
Following up on wai_tsang926's post, there's another difference between the current version of this generator and the official gridfinity spec. The corner radiuses on the bins seem to be 8mm instead of the 7.5 in the spec, but this leads to the radiuses all being concentric on the corners of the box so I actually consider it to be an improvement over the original and should be compatible with other files found online.
I forked the code to try and fix the lip geometry but when I adjusted the dimensions for the top lip geometry it also affected the bottom chamfer details because the logic of the two is tied together. The lip not being 45 degrees is bothering me so I'll continue to mess with the code but it would be nice if the main featurescript were updated to correct this geometry so I don't need to refactor my models.
This is an awesome generator! Way more user friendly than the Fusion bin generator, since you can actually go back and edit the design. However, the one feature that the F360 generator has that yours is lacking is the ability to remove the bottom 42x42mm grid on bins, making the bottom of the bin flat. Would you be able to add that feature easily?
