why does this look correct in view but prints solid.
it looks like I may have multiple problems here. the first extruded piece has a shaded blue and gray area which is different from the rest. then the first face blend is dark blue. there is something going on between these two parts that is causing my problem. when I print it, it looks like the face blend is printing solid all the way through. when I rotate it around it looks like everything is ok except the color variations. not sure if i'm doing this correctly but here is a link, i think. thanks for the help.
roller - Copy | Part Studio 1 (onshape.com)
This one is 1 Sketch and 1 Feature!
