How do I create embossed (extruded) text onto a compound curved surface?
KennyWho
Member Posts: 15 ✭
I am designing bells and barrels for clarinets to be 3D printed. I need to label the objects with pertinent information so that it can be printed as an embossment.
How?
How?
rafael_telgmann
Member Posts: 138 ✭✭✭
Hi, take a look at this document, maybe it will help you. Otherwise, it would be great if you could share a document.
https://cad.onshape.com/documents/9dfb6fa76228e8a62707bd39/w/117924f8c1d1ea5ed48fb075/e/ecefe626e9b5144852c8b702?renderMode=0&tangentEdgeStyle=1&uiState=66bb781c6edede5fac6f99ce
1 -
rafael_telgmann
Hi, I looked into this and it seems to me that this feature aligns the text to the sketch plane of the path curve. This makes no sense to me. There is another FS that works better in this situation.
Have a look…
1
https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/5b845e0994ab9181e081882b/e/8639f00c4f54af50704861a9
Help! Here's the document. It's placing the text upside down on opposite sides of the barrel. Need it to simply say 66 and be extruded inward 2mm.
https://cad.onshape.com/documents/2010946bef95e8cf07893c7b
https://cad.onshape.com/documents/2010946bef95e8cf07893c7b/w/7e7194f6ca8361ad96567bf6/e/befcbc28de5a9e75c1c61306
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/v/3f1bcca2812d650a51c9960d/e/7a70ac021729253c4df9d213
Have a look…
https://cad.onshape.com/documents/4a58a65a33b2fd6c3de63bd0/w/d47b77899272351b559bef9c/e/48dc70e6956bba4937ee1723?renderMode=0&tangentEdgeStyle=1&uiState=66befb6e5c97bf1d9d98c7cb
I made it a cut out. Works great! Now I need to study the commands and clean up the suppressed stuff.
Thanks!
