3d cad mouse "refreshes" part only when I click or when I let go of the 3d mouse.
jonah_atkinson
Member Posts: 5 ✭
in General
I'm using a 3d Connexion SpaceExplorer USB, it works smoothly in solidworks and other programs but when I use it in onshape the part doesn't move in real -time whe I move teh 3d mouse around. It instead jumps to where it woud be when I'm done moving it after I stop the moving the 3d mouse or when I click in the window of onshape. It appears to be only refreshing the position when there is and input tot he website and not in real-time as I hove the 3d mouse. Need to knwo how to fix this issue, thanks.
What platform are you on (including browser) and which drivers do you have installed?
