FS calculating plane normal
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
I'm creating a plane at an offset from a reference plane which I also want to angle at a given number of degrees.
My test code looks like this:
const p is Plane = plane(
                offsetDirection ? (refPlane.origin - (offset * refPlane.normal)) : (refPlane.origin + (offset * refPlane.normal)),
                vector(0, 0.1, 0.3)
            opPlane(context, id + "plane1", {
                        "plane" : p
How should I go about generating the normal vector to achieve the desired angle?
Thank you.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 400 PRO
    FeatureScript transforms are great, they do a lot of heavy lifting for you.
    If you create a rotation transform:
    var rotationangle = rotationAround(X_AXIS, 30*degree);
    var newVector = rotationangle*oldvector;
    The one thing is that it only works with vectors that have a length.
    So you'll need to take  your normal, give it units (ie oldvector*meter), rotate it, and then remove units (newVector/meter)
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you.
