having some trouble with opChampfer
Hello everyone,
I tried adding an opChampfer to my script.
But for some reason, it showed me an Error regarding the ChamferType:
The only way to "fix" this was to delete the chamferType-line entirely.
But now it will create only chamfers with equal offsets, even when I add the angel to the map.
Did I miss anything?
https://cad.onshape.com/documents/18bc9429cf74f25bda45bcb3/w/0a904f6ed90ecee8ff26b88f/e/265b505d5756f251893ce08e
Thanks in advance
Philipp
  • _anton_anton Member, Onshape Employees Posts: 534 image
    ChamferType is defined in chamfertype.gen.fs, which you'd need to import. export import(path : "onshape/std/chamfertype.gen.fs", version : "2411.0");
  • philipp_baumann477philipp_baumann477 Member Posts: 5
    edited August 2024
    Thanks @_anton,
    Thank you for the quick answer.
    I almost expected something like this and I had searched the documentation for an import I might need but hadn‘t found anything.
    To avoid this type of issue in the future, where do I find what to import to use certain features?
    Thanks
    Philipp
    Good question. I go to the FS standard library (https://cad.onshape.com/documents/12312312345abcabcabcdeff) and find a tab I'd expect to have the right import (chamfer.fs in this case). Then I see how it gets the import.
    Well, seems quite complicated, but at least I now know where to look.
    Thank you.
