Linear pattern
mario_darceuil
Member Posts: 113 ✭✭
Why when I click on the linear pattern tool, the object to be patterned disappears off the screen? Sometime it works and at other times it never works. What can I possibly be doing wrong? This is such a nuisance.Please help, I've wasted so much time trying to deal with this.
Linear pattern in the sketcher or part/feature patterns? I've never had this problem. Are you working at a very small or large scale? The defaults for pattern step sizes might be an issue.
Onshape sketcher. Just patterning a circle of 0,25 inches in diameter,
Of course I will try again. but it happens where it is not working.
That sounds really strange. Are you using an unsupported browser or is there anything else special about your setup? Maybe raise a support ticket if it is something that you can clearly reproduce.
I am using Chrome.
