Double-triangle sweep
AreoResearch
Member Posts: 2 ✭
Hi,
Ive been lately trying to make frame model, but the sweep tool dont work if you select more than 2 lines emerging from one point, any solution? Is there better way to do this?
Thanks for the answers,
VM
Try using the frame tools.
https://www.onshape.com/en/features/frames
Like S1mon said, Use the "frame" command - but you might not be able to select all paths at once, you may have to make multiple frames to do the job. In addition, selection order matters - so that miters end up looking the way you want (little bit of trial and error here). There is a learning curve, but in the long run, it's still probably the best way to get what you want. Hope this helps
