Revolute mate limit direction
gerald_friedman
                    OS Professional Posts: 50 ✭✭
                    How does one control the direction of rotation when specifying Revolute mate.
Sometimes it moves in the direction I want and sometimes not.
After playing for a while I can get it to do what I want but don't know what I've done...
gerald_friedman
                    I believe I've figured it out.
Has to do with the order of which the mate connectors are selected.
At least it's working for me now.
And "good luck" is not an answer.
Please, someone else try and let me know the result.
Thanks,
g
5
Thanks,
g
I also found it handy to have the mate shown which show's the directional arrow.
BTW are there use cases to allow more than +360deg and less than -360deg values for rotational limit?
brucebartlett For relation you can also make them rotate opposite to default by choosing 'Reverse direction' in relation dialog. Did that not work for you or you didn't notice?
I'm sure the onshape team is aware that users struggle with mate limits and they will address it soon. Until then...good luck.
If the first ones chosen don't result in the proper direction, delete them and choose in the opposite order.
Been working for me all the time now.
I'll have to learn a new operation when a negative angle is allowed to be entered in the future.
However, thanks to this topic, I now have a solution to how to reverse the direction of rotation.
Thanks Gerald.
Unfortunately, I'm struggling with this too
