Drawing a corner rectangle centered about the origin
ken_s_
Member Posts: 1 ✭
I need to drawing a corner rectangle centered about the origin. A 2D question.
I draw a rectangle and all I can think to do is midpoint-constraint two of the sides.
I placed two perp. construction lines passing through the origin, one X, other on Y-axis.
This works for one side, the rectangle shifts and centers itself on one axis about the origin. Looks good so far.
I try the second rectangle-side midpoint constraint, and the rectangle disappears. All I see are a lot of constraint flags.
I'm not sure what happened. How do I draw this in Onshape?
NeilCooke
Moderator, Onshape Employees Posts: 5,979
Center Point Rectangle (under corner rectangle)Senior Director, Technical Services, EMEA5
Is there no way to align this after the fact? Seems like it would be useful in case you made a mistake or need to modify a sketch. How do you align a rectangle sketch to the origin after the fact? I've been reading and searching the docs and I can't seem to find a clear answer for this.
I assume you mean a rectangle without a center? You can use the midpoint constraint with two diagonal points of a rectangle and the origin. Just make sure that the origin is inside the rectangle first.
