Cannot access Certificate
Hello I seen some varying results with searching this question, and i believe I have done everything correct but have not yet recieved my Certificate for the Self Paced courses yet. I have completed the servey but I do not have access to multiple certificates. What am i doing wrong?
  • Lindsay_EarlyLindsay_Early Member, Onshape Employees, Developers Posts: 26 image
    Hello Nicolas. Each page in a course requires you to view it for 3 seconds before it counts as complete. Make sure you have green checks next to each topic and all the subtopics (like under the exercises) show fully green circles instead of orange. When the course is complete you'll see 100% complete at the bottom and that is when the certificate is issued.
  • tanguy_nieltanguy_niel Member Posts: 2 EDU
    Hello,
    I have the same problem with the Learning Pathway 'Onshape Fundamentals.'
    I have checked all the courses, and they are all at 100% completion.
    What is missing to obtain the certificate?
    edited August 2024
  • Alexandra_MeiserAlexandra_Meiser Member Posts: 3 PRO
    edited August 2024
    I am also having this issue, where I am unable to complete the pathway but all prereqs are checked as complete on the pathway page and the survey shows as completed in my dashboard.
    edited August 2024
    edited August 2024
