Sheet Metal and Mirrored part question
andrew_jackson232andrew_jackson232 Member Posts: 6
Hi all,
https://cad.onshape.com/documents/769333ed394d42bc3e118b5d/w/1e08bcd9af861c60089739f8/e/b999c0f62b6a4c99062cb6cd?renderMode=0&uiState=66cb0cb79d73292750a32ff9
I'm struggling with a few features. I have created a sheet metal part with a flange, i don't seem able to lengthen the flange past the edge of the part as shown below. Is this possible? I have tried playing around with offsets but i'm a little confused and i tend to brake it.
So as a work around i created a new sheet metal part off of the edge where the arrow is which created a new part 'Part 2'.
While i can draw of this I'm not able to add fillets so i thought i would try a different way and added the feature but i'm not able to extrude it.
My question is, how am i best to approach this as i'm not sure how to achieve what i want?
My last question is, once i have mirrored this, how can i make changes to the mirrored part without it affecting the original part? I want to remove some of the flanges and also slightly modify the shape as they are not completely symmetrical but are close that i think mirrored part would be the best starting point.
Many thanks from a complete novice who is enjoying the process of learning CAD.
  • glen_dewsburyglen_dewsbury Member Posts: 1,081 PRO
    Have a study of this example. I changed some sequencing for the Flange and used Tab after the mirror. Also, you can trim in the flat view.
    https://cad.onshape.com/documents/bb8ed48cc90a3d57a596f5a6/w/5f0190f60e10eebee12218da/e/b69fe5199d6b64db25482f45
  • andrew_jackson232andrew_jackson232 Member Posts: 6
    Many thanks Glen, i will have a play with your example and see what i can achieve. I didn't think about editing in flat view so i'll also give that a go.
    KR
    edited August 2024
    Definitely have a run through the simultaneous sheet metal course.
    Here's the link:
