Improvements to Onshape - August 29th, 2024
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 220
edited September 2024 in New in Onshape
It has only been 17 days since our last release, and we are back with another one. This update includes a long list of improvements in areas like assemblies, drawings, and more. Let's dive in.
ASSEMBLY IMPROVEMENTS
LOCK/FOLLOW SUBASSEMBLY
You can now lock the position of a subassembly within a top-level assembly. When enabled, the movement of the subassembly is restricted. You also have the option to follow a subassembly named position. This allows you to use named positions from the subassembly to orient the subassembly in the top level.
https://onshape.wistia.com/medias/ogxsl8ba1r
ISOLATE AND MAKE TRANSPARENT ASSEMBLY FOLDER
Folders in the Instances list of an assembly can now be isolated and made transparent.
https://onshape.wistia.com/medias/yub1ne6w00
IMPLICIT MATE CONNECTOR IN ASSEMBLY PATTERNS
It is now possible to use implicit mate connectors when defining an assembly pattern. This makes it easier to create patterns with geometry that doesn't have an easily defined reference.
https://onshape.wistia.com/medias/p315ctsx8x
SET TO MIN/MAX MATE LIMITS
You can now set a mate's position to either its minimum or maximum mate limit value.
https://onshape.wistia.com/medias/84o52s47rx
REORDER NAMED POSITIONS
Named positions can now be reordered. When right-clicking a Named position you will see new options to Move up or Move down.
PART STUDIO IMPROVEMENTS
NORMAL TO FACE CURVE PATTERN
You will find new a new Normal to face orientation option when creating Curve pattern features in Onshape. This new option creates a pattern that is normal to selected faces at each pattern instance along the curve.
https://onshape.wistia.com/medias/9qvs3vcmm4
DRAWING IMPROVEMENTS
NOMINAL AND TOLERANCE COLUMN IN INSPECTION PANEL
You can now add Nominal and Tolerance as a single column to your company's Inspection tables. In the past, these were only available as two separate columns.
https://onshape.wistia.com/medias/v609eoo26a
GROUP CALLOUTS WITH VIEW
You can now group callouts with a view. When grouped, callouts move with the view.
https://onshape.wistia.com/medias/68pc16jr4p
GENERAL IMPROVEMENTS
CLEAR ALL SELECTIONS
When right-clicking a set of selections, you will find a new option to Clear all selections. In the past, the only way to clear all selections was the spacebar.
https://onshape.wistia.com/medias/pu6p22l0mq
RELEASE MANAGEMENT IMPROVEMENTS
RESET PART NUMBER TYPE
You will find a new company setting for Change Part number type under Revision tools. This new option allows you to reset a given part number, allowing it to be used by a different object type.
https://onshape.wistia.com/medias/9bszcv2px8
LEARNING CENTER IMPROVEMENTS
The Onshape Learning Center has a completely new landing page with buttons to guide you on your learning journey. The CAD Basics and Onshape Fundamentals pathways have been updated with new content essential to succeeding in Onshape.
  • Kaushal_SharmaKaushal_Sharma Member Posts: 1 PRO
    Locking the position of a subassembly within a top-level assembly is very cool.
  • xTimRicexTimRice Member Posts: 61 PRO
    BIG assembly motion improvements here!
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
  • Caden_ArmstrongCaden_Armstrong Member Posts: 263 PRO
    Good stuff is always tucked in the changelog notes. New qInFrontOfPlane is nice.
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • S1monS1mon Member Posts: 3,298 PRO
    Tricky. The last release got delayed until a Monday, and here we have a slightly early Thursday release (perhaps in deference to US Labor Day weekend?).
    Definitely some good quality of life improvements.
    Lock/follow is great. I could imagine some people/companies wanting Lock to be the default. Perhaps a future improvement?
    I'm going to have to play with the normal to face curve pattern option and try to recreate some of the more painful patterns I've see in the past.
  • STEGSTEG Member, User Group Leader Posts: 109 PRO
    Nice features for assembly 👌🏻
    And great to have space mouse support in render studio too
  • martin_kopplowmartin_kopplow Member Posts: 758 PRO
    Looks great! I'll have to play around with some, but lock/follow assemblies is my immediate favourite, together with set to min/max for mates, followed by SpaceMouse support in RenderStudio and normal to face curve pattern. Overall, I expect this update to make life easier in quite some critical places.
    Callouts grouped with drawing views should be default, though. Ungroup only when needed.
  • christopher_dziubachristopher_dziuba Member Posts: 84 ✭✭
    Oh wow wasn't ready for this one. Short and sweet, good work team!
  • Simon_KozinSimon_Kozin Member, csevp Posts: 9 PRO
    I just wanted to say how well put together these summaries are. The post is short and simple but it makes it easy and enjoyable to keep up to date with the improvements. The short videos are well done and generally enough to convey the changes. I find this is the only "change summary" that I read regularly. Thank you!
  • birger_kullmannbirger_kullmann Member Posts: 4
    NiceI will check it out for sure.
    Onshape has always been mostly excellent except for the last 2 or 3 days And this is why I am posting here.
    Some of my assemblies suddenly are empty or partly empty ? (parts and subassemblies only showing in tree. Not hidden or suppressed.)
    Two tickets are sent and 'I'm unable to use Onshape since parts keep disappearing when I bring up older versions.. No answer so far.
    Solution will be much appreciated as I do this for a living.
    BR
  • danny_paynedanny_payne Member, User Group Leader Posts: 40 PRO
    Great improvements to assembly and drawings. I always love the drawing improvements.
  • Michael_BillsMichael_Bills Member Posts: 26 PRO
    I had a support ticket halfway written, asking if the devs could force one of my part numbers to be reusable as an assembly number… and now they've given me the ability to do it myself. Thanks!
    it’s getting to be that time again…😀
  • rafael_telgmannrafael_telgmann Member Posts: 126 ✭✭✭
  • eric_pestyeric_pesty Member Posts: 2,157 PRO
    Hmm, just saw this (show FS version 2455!):
  • glen_dewsburyglen_dewsbury Member Posts: 1,017 ✭✭✭✭
    I just saw that as well. Way cool for spotting under constrained sketches.
