Diameter symbol in 2D drawing derived from a 3D model
henning_michel_henning_michel_ Member Posts: 19 EDU
Hi,
when I apply dimension to a circle I get the proper diameter-symbol. When I try to add the diameter symbol to a non-circle-dimension manually, I get the ugly oval. When I copy the proper diameter-symbol, it turns into the oval.
How to I get to proper diameter-symbol in any dimension?
