Diameter symbol in 2D drawing derived from a 3D model
henning_michel_
Member Posts: 19 EDU
in Drawings
Hi,
when I apply dimension to a circle I get the proper diameter-symbol. When I try to add the diameter symbol to a non-circle-dimension manually, I get the ugly oval. When I copy the proper diameter-symbol, it turns into the oval.
How to I get to proper diameter-symbol in any dimension?
Interesting. They all appear the same for me. And mine look nothing like yours. Are you using a special font perhaps?
RENDERCAD
I am using ARIsoP1 as font for all dimensions.
The trick is, to first dimension the circle in a top view where the circle is visible. Then dimension the circle in a side view where the circle is not visible. The correct diameter-symbol then gets inserted automatically.
however, the trick does not work in this case:
Not sure how to help you there, you may have to open a support ticket. If it is a font issue the only thing you can really do is change the font. Sounds like that font has an upper and lower case diameter symbol if that is even possible.
RENDERCAD
