FS Plane at angle
graham_lock
Member Posts: 265 PRO
Hi all,
I'm creating a plane at angle using cPlane:
cPlane(context, id,
"entities" : definition.edges,
"cplaneType" : CPlaneType.LINE_ANGLE,
"angle" : 0 * degree
How do I get a reference to the generated plane?
I know cPlane uses opPlane but to replicate that code seems inefficient?
Is there better way to generate the plane?
Thank you.
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Just like any other feature, send an id you can use qCreatedBy on, such as id + "plane"
Senior Director, Technical Services, EMEA0
Thank you/
