Adding a textured surface to a model
Is there any way I can add a rough finish (like a sandstone surface or Cura's Fuzzy skin) to a surface within onshape?
  • MichaelPascoeMichaelPascoe Member Posts: 2,685 PRO
    edited September 2023 Answer ✓
    Hey @paul_everington, it is possible to create larger textures like knurls or patterns. See this post as an example Texture. The textures you mentioned are most likely too detailed of textures for Onshape to handle in the part studio.
    Is this only for appearance or are you trying to 3D print the model?
    If you are only going for appearance, Onshape's Render Studio can achieve almost any texture you like. Though you would need either a Pro or Enterprise account to access the beta.
  • paul_everingtonpaul_everington Member Posts: 5
    Thank you Michael.  Yes, it was for 3D printing and I thought it might be overly detailed for onshape to handle.
  • benjamin_gregorybenjamin_gregory Member Posts: 2
    do I need a paid account in order to add texture or surface finish to a part, id like to get more in depth with 3d printing. I am a hobbyist if it matters.
    edited September 2024
    @benjamin_gregory Free accounts get custom features too! Just open the document for that custom feature then click the (+) button near the top middle of the screen.
