Formating dimension text in Drawings
in Drawings
The size of the text for dimension numbers in my drawings is way to large.
Is there a way to format the text and arrow sizes to have it fit my drawings better?
Use the properties panel on the right. If you edit your drawing template it will be the same for all future drawings.
Thank you, but I am not seeing where you can change font size, or arrow size.
@jack_erhart The controls are here:
There are no options in the drop down menus for the size of the text or the arrow heads. Am I missing something?
You can just type the number for the size you want…
Very cool! Thanks for your help.
