Equation not working. Need help
Ben_Ben_ OS Professional, Mentor, Developers Posts: 304 PRO
edited November 2017 in Community Support
I have this equation for a dimension using variables:
(245-((#ARC1+#ARC2)))/2
The first minus sign after 245 is the problem. When digging into this to see what is wrong, If I try a minus, plus, division operator it does not work. If I try a multiplication operator it does work.
(245-((#ARC1+#ARC2)))/2 gives error "enter a valid function"
(245+((#ARC1+#ARC2)))/2 gives error "enter a valid function"
(245/((#ARC1+#ARC2)))/2 gives error "enter a valid function"
(245*((#ARC1+#ARC2)))/2 works
What am I doing wrong or is this a bug?
    Do either of the variables have units? It might be worth removing the units from the variables and adding them in the dimension instead.
    No units they are copy and pasted from the dialog
    did you tried (245-(#ARC1+#ARC2))/2 or (245-#ARC1- #ARC2)/2 ?
  • abefeldmanabefeldman Member Posts: 166 ✭✭✭
    Abe Feldman
    UX/PD/Community Support
    Neither of these work unfortunatley
  • lanalana Onshape Employees Posts: 727
    @Ben_
    Does (#ARC1+#ARC2) / 2 work?
    lana said:
    @Ben_
    Yes that portion of the equation works but as soon as I try and subtract it from 245 is does not
    Testing this out I set
    ARC1 = 45 deg
    ARC2 = 45 deg
    All of the equations but the last fail because 245 does not have consistent units with either of the variables.
    Changing the variables to the "Any" unitless option succeeds:
    ARC1 = 45
    ARC2 = 45
    Or you could enter ((245*deg)-(#ARC1+#ARC2))/2, but be sure there's no "deg" unit appended to the end.
    Abe Feldman
    ARC1 = 45 deg
    ARC2 = 45 deg
    ARC1 = 45
    ARC2 = 45
    I have not used degree units! The ARC1 and ARC2 are lengths defined only by a number in my document (FYI they are arc lengths not arc degrees)
    I need to eat a little crow now... In the end if I added mm to the 245 it works thus (245mm-(#ARC1+#ARC2))/2 works but (245-(#ARC1+#ARC2))/2 does not.
    It would be nice if the variables defaulted to unitless. IMHO
  • JanaLumiJanaLumi Member Posts: 4
    edited September 2024
    I'm having the same issue. Cannot remove the units from the variables, nor does it access units in the calculation.
    For example, in the calculation:
    ((#depth/#joins))-0.2) mm
    → this works
    (#depth/#joins)+#adj
    (#depth/#joins)+#adj mm
    → neither of these are accepted and I get the error message: "cannot subtract unitless number and length"
  • S1monS1mon Member Posts: 3,326 PRO
    (#depth/#joins) is unitless.
    #adj has units.
    you could do (#depth/#joins mm)+#adj
    What you probably want to do is switch joins to be a number not a length. Then the equation would be #depth/#joins + #adj.
