Linear rails / carriages in assembly
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
I have an assembly containing a linear rail / carriage pair, they are mated with a slider mate.
I want to add two of these sub assemblies into the main assembly, parallel to each other.
What do I need to do to make the carriages track each other?
Thank you.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 844 PRO
    A Planar mate would do it. Or a Fastened with an offset.
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you.
    I tried the fastened mates approach but that stopped either carriage from sliding?
    The planar mate works perfectly!
  • _anton_anton Member, Onshape Employees Posts: 505 image
    What would make them track each other in the physical assembly? Would there be, e.g., a gantry connecting the carriages? Fastening that to both would achieve the desired result. Alternately, planar mates.
    Thank you.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 696 ✭✭✭
    Where did you place the fasten mates? - Scotty
    Hi,
    I placed them at one top corner of each of the carriages and at the bottom matching corners of the gantry profile.
    Perhaps you need to offset the mate connectors you're using for the fasten mates.
    Thank you - I’ll try that.
