sweep construction entities
darren_mason871
                    Member Posts: 44 ✭✭
            I made construction lines on 2 planes and 3D filleted the corners. There is a circle at the beginning and I tried to sweep but it is rejecting the entities I've selected for the sweep path. It says check that selections are not construction entities. Here's a link an picture:
https://cad.onshape.com/documents/d6fdebd8ff80ccf3cba99af7/w/6864dd0ffa881c4ea7700412/e/cde138af40fc39d9fe25df89
I'm not certain, but this may be because each section of your path is defined in a separate sketch, whereas from the description in the help video they must all be part of the same sketch:
It's not clear, but I interpret that to mean sketch entities within a single sketch. Certainly the error message you're getting is confusing in this case.
Hey Darren. It works. Check your selections. - Scotty
triple sweep thread - Copy | Part Studio 1 (onshape.com)
Where is this video? I looked at an online tutorial and I can't figure out how to do get the precision selector to appear when I try to use multiple planes in one sketch
Are u saying my original file works without u changing it? And if so what do I change about my selections
Works for me too with out changing any of your sketches. Are you selecting whole sketches? I selected individual curves displayed. i suspect there are things eft behind after the 3D fillet that are being selected that have overlaps of curves.
https://cad.onshape.com/documents/0c72466bf89c8fd607f3278e/w/0bd51833a853a1ad033d4ef6/e/3a735b2b72d5bee2a31ca107
