Next number in part number scheme feature script
How can I modify my featurescript for an O-ring part studio to automatically generate next part number for each new configuration, following the in-built onshape numbering scheme? Currently, I have to manually enter the desired configuration in the properties and create a version within the part studio. I have read that previously any new configuration that is imported to an assembly would automatically get a new line in the configured properties, but it doesnt seem to be the case.
FeatureScript 2433;
import(path : "onshape/std/common.fs", version : "2433.0");
annotation { "Feature Type Name" : "Description with variables" }
export const descriptionWithVariables = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Part", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
definition.part is Query;
annotation { "Name" : "ID" } isLength(definition.ID, LENGTH_BOUNDS); annotation { "Name" : "Thread" } isLength(definition.thread, LENGTH_BOUNDS); annotation { "Name" : "Material" } definition.myMaterial is MaterialOption; } { const IDString = makeLengthString(definition.ID, 5, millimeter, "mm"); const threadString = makeLengthString(definition.thread, 5, millimeter, "mm"); //const materialString = definition.myMaterial; // Manually set the materialString based on the enum value var materialString; if (definition.myMaterial == MaterialOption.ONE) { materialString = "FKM 70"; } else if (definition.myMaterial == MaterialOption.TWO) { materialString = "NBR 70"; } else if (definition.myMaterial == MaterialOption.THREE) { materialString = "EDPM 70"; } setProperty(context, { "entities" : definition.part, "propertyType" : PropertyType.NAME, "value" : "O-ring," ~ IDString ~ " x " ~ threadString ~ ", " ~ materialString }); setProperty(context, { "entities" : definition.part, "propertyType" : PropertyType.DESCRIPTION, "value" : "O-ring, " ~ IDString ~ " x " ~ threadString ~ ", " ~ materialString }); });
export function makeLengthString (value is ValueWithUnits, precision is number, unit, unitString is string) returns string
return roundToPrecision(value / unit, precision) -> toString() ~ " " ~ unitString;
export enum MaterialOption
annotation { "Name" : "FKM 70" }
ONE,
annotation { "Name" : "NBR 70" }
TWO,
annotation { "Name" : "EDPM 70" }
THREE,
NeilCooke Moderator, Onshape Employees Posts: 5,878
There is no way to automate this, manual only I'm afraid.
Senior Director, Technical Services, EMEA1 -
Caden_Armstrong Member Posts: 300 PRO
This can't be done with FeatureScript, but it can be done with the API.
www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications1
Anyone?
