Scale part to specific size
john_doe639
Member Posts: 7 ✭
I have a large part that I imported. I need to scale it down to 10mm x 5mm. But when I use Transform|Scale, it won't let me enter units (like mm). Is there a way to scale something using specific units as a goal? (This is a non-uniform scale if that matters).
You can use the desired size divided by the current size to get the scale.
Thanks. Finally got around to doing this and it worked perfectly.
