Modeling a Heart
Hi all,
Learning Onshape (and loving it)...I'm designing a ring to 3D print for my daughter Anita's 12th birthday...I'm getting there but I'm having trouble modeling a little heart where you can see the sketches...https://cad.onshape.com/documents/7aa57cf32b85467194417695/w/139f014241e241119e21b702/e/65fbd6cfa960421184c4839d
I tried loft from one point (sketch 7) through 6 and other point (sketch 8), using 9 as guides...but no luck. I guess a tool such as revolve along guides could do the trick...Ideas anyone?
Thanks
Giacomo
Thanks
Giacomo
https://cad.onshape.com/documents/3590d0cbc37e48039b13d963/w/7ccd8463ab394b468472f92e/e/0ab86d455ba14dc5bcfc110c
That's a tricky shape to produce at present in Onshape.
Here's one approach which works: lofting between three profiles as shown, and then mirroring about the midplane (AT Plane 7 in the modified model)
Model is at
https://cad.onshape.com/documents/f1a95b7a51794b6cb051ff2d/w/e1a6d78e002345dfb8aef904/e/705add33489b44f29eb6579c
I had to edit a couple of your earlier sketches to get it to work, notably your sketch 9 (shortening it to make it suitable for a guide curve)
There's one more "mirror" feature needed to produce the shape you want, about the Top plane
Che dire la mia ???
I beg your pardon! I was sure I replied to you!...I just put a Vote Up instead...sorry! Thank you very much for your time and kindness...I've already ordered the ring for my daughter! Here: https://www.shapeways.com/designer/giacomo_ardesi
Nice result. Thanks!
