Help using sweep to create an inverse fillet
Hello,
I'm having trouble creating an "inverse fillet". My goal is to recreate the bottom fillet on a box for the top edge so they can be stacked easily.
Here's my current drawing. Sweep works nicely when I select the circle for the form and a single edge. As soon as I try to follow the edge and select one of the corners, OnShape fails because the sweep intersects. Doing each edge in a separate sweep doesn't do what it's supposed to - supposedly because of the circles orientation in the sketch.
My next try would be to create a sketch for each fillet, but that seems excessive and I hope there's a better way. Looking forward to any tips!
Thanks,
Jan
