INTRODUCTION TO PART STUDIOS - ADVANCED FEATURES / EXCERCISE:FUNNEL
Hello,
I am currently working through the Introduction to part studios advanced features exercise funnel on the OnShape tutorials. This is driving me crazy, i am on part 9 trying to loft the profiles but it will not work no matter what I try. It keeps highlighting the inner line red and not allowing the loft to happen. Any help would be appreciated!
Here is the Link to the document
https://cad.onshape.com/documents/c8f6d1461a3ed2645c796df3/w/c5149d4d45671162ad88071f/e/8be0f12b69649e827da2c0cf?renderMode=0&uiState=66f2da5ae0769c1647f6f5f6
Thank you for your time.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    Your document isn't public, so it's hard to see the issue with the loft, but your sketches look good. Here it is working:
    https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/0eecb85582340404ace05026
  • adriano_borgiaadriano_borgia Member Posts: 5
    I have adjusted the access, It should be public now. I looked through yours and it seems exactly the same. I have no idea why mine is always failing. I have tried deleting the whole part and starting from scratch, and i always get to the same failure.
    It's really hard to grab the right profile from sketch 1 without also grabbing the inner loop. Either select the sketch from the Features list or check off "disable imprinting."
    Holy Cow!!!!! Yess!!!! Thank you so much!!! That worked perfectly! I just choose the sketch from the feature list and it instantly was happy!! I didn't realize the inner loop error was referring to grabbing the wrong curve.
    Thank you again Matt!
  • bob_mcdonald480bob_mcdonald480 Member Posts: 4
    I could really use some help on the same step of the same tutorial. I don't think I'm having the same issue as the original poster. Here is my document: https://cad.onshape.com/documents/43085388e6f62f3856c06798/w/b779645134ac855687917a26/e/164178c91479742339f3da17?renderMode=0&uiState=67c009e0cdbfd849b6da75ae . You'll see if you edit the loft, that I'm trying to create an add loft, but I always get the warning "Boolean resulted in no geometry change. The parts either do not intersect or are totally contained. " I have redone the exercise from the beginning at least 4 times now, and I can't see what I'm doing wrong.
    Any pointers would be greatly appreciated.
    I got it to work, and I have no idea why it made a difference, but the key was selecting the profiles by clicking the sketches in the feature list rather than clicking them on the model itself. So I guess my issue was the same as Adriano's in the end
  • robert_weissburgrobert_weissburg Member Posts: 33
    I was asking about this in my own thread, but Matt linked me here. I have tried about 50 ways of doing this and nothing works any better. This is the result from having disable imprinting checked. I always select the sketches from the list, not the drawing. It just never connects the funnel to the rim.
    I don't really understand what Matt is saying in his comment above, "It's really hard to grab the right profile from sketch 1 without also grabbing the inner loop."
    What's the inner loop? The inside edge of the rim's lower surface?
    If I rotate the drawing to look at the lower face and move my cursor over the rim surface (or handle), either the inner edge of the rim is orange, the outer edge, or, if in the central region, both are orange highlighted. I've tried all. I assume it should be both, apparently meaning your are pointing at the surface (I'd think the surface would turn orange, but this never happens).
    The offset ellipse generated is aligned with the lower plane of the rim, so that appears to be what is wanted in this step.
