Frame profile library not updating
graham_lockgraham_lock Member Posts: 256 PRO
Hi,
I created a frame profile library with documents organised into folders.
I versioned each document and it worked fine.
I've now updated some of the original documents and added some new ones in new folders.
Each updated document was given a new version and each new document was versioned.
I then right clicked the profile folder and selected Update my library and got the green success notification.
The problem is that when I reference the library I'm only seeing the original profile set - no updates, no new folders and no new profiles.
I've been through the update process several times.
Any help appreciated.
  • GWS50GWS50 Member Posts: 481 PRO
    I've had this quite often and the only way around it is to quit the browser and then restart it. After doing this I find that the Profile library will update.
    BTW you have to also right click the Profile Folder on the Documents Page and select update 'Your name' Frame Library
  • graham_lockgraham_lock Member Posts: 256 PRO
    Thank you - quitting the browser and restarting seems to have done the trick!
