INTRODUCTION TO PART STUDIOS - ADVANCED FEATURES / EXCERCISE:FUNNEL
Hello,
I am currently working through the Introduction to part studios advanced features exercise funnel on the OnShape tutorials. This is driving me crazy, i am on part 9 trying to loft the profiles but it will not work no matter what I try. It keeps highlighting the inner line red and not allowing the loft to happen. Any help would be appreciated!
Here is the Link to the document
https://cad.onshape.com/documents/c8f6d1461a3ed2645c796df3/w/c5149d4d45671162ad88071f/e/8be0f12b69649e827da2c0cf?renderMode=0&uiState=66f2da5ae0769c1647f6f5f6
Thank you for your time.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 683 EDU
    Your document isn't public, so it's hard to see the issue with the loft, but your sketches look good. Here it is working:
    https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/0eecb85582340404ace05026
  • adriano_borgiaadriano_borgia Member Posts: 5
    I have adjusted the access, It should be public now. I looked through yours and it seems exactly the same. I have no idea why mine is always failing. I have tried deleting the whole part and starting from scratch, and i always get to the same failure.
    It's really hard to grab the right profile from sketch 1 without also grabbing the inner loop. Either select the sketch from the Features list or check off "disable imprinting."
    Holy Cow!!!!! Yess!!!! Thank you so much!!! That worked perfectly! I just choose the sketch from the feature list and it instantly was happy!! I didn't realize the inner loop error was referring to grabbing the wrong curve.
    Thank you again Matt!
  • bob_mcdonald480bob_mcdonald480 Member Posts: 4
    I could really use some help on the same step of the same tutorial. I don't think I'm having the same issue as the original poster. Here is my document: https://cad.onshape.com/documents/43085388e6f62f3856c06798/w/b779645134ac855687917a26/e/164178c91479742339f3da17?renderMode=0&uiState=67c009e0cdbfd849b6da75ae . You'll see if you edit the loft, that I'm trying to create an add loft, but I always get the warning "Boolean resulted in no geometry change. The parts either do not intersect or are totally contained. " I have redone the exercise from the beginning at least 4 times now, and I can't see what I'm doing wrong.
    Any pointers would be greatly appreciated.
    I got it to work, and I have no idea why it made a difference, but the key was selecting the profiles by clicking the sketches in the feature list rather than clicking them on the model itself. So I guess my issue was the same as Adriano's in the end
