Creating planes perpendicular but off angle
MDesignMDesign Member Posts: 1,286 PRO
So this project of converting this mesh to solid has been quite the learning process and I keep thinking there's got to be a better way than I'm doing it which is and excessive amount of planes/sketches/constraints/faces. I haven't found another way or another software yet. Ideally a mesh editor that lets me define mesh planes and complex surfaces with splines referencing the mesh but not 'glued' to it….would be ideal. but I haven't found that solution yet.
So my question comes as how do I create a plane perpendicular to another plane. line and angle doesn't work as it seems the 0 angle is arbitrary in my case. but essentially the plan I want to create is perpendicular to the planes under my red arrow. that edge of the mesh is on angle from the top view and is not parallel to the edges of the planes under the red arrow. Ultimately I want to create a surface to follow the mesh but smooth for the most part. and I want that front edge at the arrow to be tangent to a perpendicular plane off those planes below the arrow. Does any of this make sense? kinda hard to explain.
I tried sketching a line on the plane I want be perpendicular to and using line/angle but the angle relative to the sketched line plane is unknown.
