Linear pattern not extruding on all parts
Hey Folks,
Im having a small issue working on a design and think I'm again missing something ovbious. Im recreating a part I created super fast in tinkercad and am struggling in onshape. Overall width should be 55mm and length should be 335mm with the 4 central plates extending over the edges. Theres 23 holes in each horizontal bar, and should be 37 bars in total. the rest of the dimensions are not massivly important.
I created this with a sketch and extrusion creating the the 4 long plates on the bottom, then a sketch designing the horizontal bars and finally a sketch with a linear pattern for boring the holes through everything. So far so good.
Now when creating a linear pattern of the bars with the holes in they are ot going through the long plates on the bottom even though they are doing so on the original.
Im not sure what is wrong, but can only assume its because my initial sketch is underdefined, but I'm not sure how much more definition it needs as all measurements are defined
https://cad.onshape.com/documents/816278c1aea087330ff39d4c/w/568302bdcf722c0a15337d3e/e/b7f795b1768ed22be2350375?renderMode=0&uiState=66faa240eebf9065d35020e8Error
If anyone would be willing to explain what I've done wrong that would be great for defining my knowledge.
    You are doing a part pattern, which does of course copy that part complete with holes, but then doing a boolean union, where your long rails do not have holes so this of course results in no holes there.
    You would be better off doing a feature or face pattern here.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 844 PRO
    You are patterning a part. A part with holes in it. You aren't patterning the holes, so there is no reason Onshape will add holes to the existing parts.
    You could pattern the holes after the boolean:
    https://cad.onshape.com/documents/e2126cac1986b29db8bdb4a2/w/50ac20af10fd45814fb38a1b/e/617871fae5499e8c3404afe4
    Or just do the whole thing as a feature pattern:
    https://cad.onshape.com/documents/e2126cac1986b29db8bdb4a2/w/50ac20af10fd45814fb38a1b/e/f0e74e0cf954ea628740ef9e
  • gary_smith251gary_smith251 Member Posts: 11 EDU
    But the holes in the long rails come from the first part in the pattern, so why are they not copied to the other parts when using linear pattern if they are through all subtraction in the first part?
    edited October 2024
    There's an important difference between copying a feature and copying geometry which was affected by a feature.
    The feature makes the holes in your 2 parts, so there are 2 holes even though in your case they are in the same place. When you pattern a part with a hole you only get the hole in the part you copy. When you pattern the hole feature it creates new holes in the parts you select for it to make holes in.
    You should go through the tutorials in the learning centre
