edit appearance wonn't change part color
joshtargo
Member Posts: 472 EDU
Part has been assigned transparent gray, stays black.
https://cad.onshape.com/documents/4effa3499c0e0efa32ae93dd/w/32b7d498cede754b21ba0554/e/e94007c450c9aafb49fcfa9d
For the back part, it has Face Appearances assigned (auto assigned during the import) that are overriding the Part Appearance. Navigate to those Face Appearances in the Appearance Panel and choose to "Disable Imported Appearances". Alternatively, you can edit the Import feature and uncheck that box option.
Thanks! never used that panel. some of the students are very insistent that onshape uses the colors from their Inventor models
Thanks for the tip.
For their sake, note that disabling the imported appearances only removes the "Face Appearance" and the underlying part appearances should still match the original file! Glad I could help
When they exported step files, random colors would be assigned, so now they're doing parasolid, and it's working better. The imported appearances box was not checked when I looked at that document.
