Imported image not extruding correctly
 ian_leavesley
                    Member Posts: 6 ✭
ian_leavesley
                    Member Posts: 6 ✭
            An imported DXF image that I uploaded to onshape to make a stencil is not extruding correctly. Most of the image is extruding/removing correctly apart from one letter. If I try to extrude/remove the one letter it will cause an error, however if I do extrude/add then it works fine. Any ideas on how I could solve this?
I've added two images for clarity and the document is also public : vloonlogo
Any help would be greatly appreciated.
Possibly an open sketch in the imported DXF. I you can post a public link to the document someone will give suggestions on how to fix.
Thanks Glen, here is a link to the document:
https://cad.onshape.com/documents/b222f17f80a65baa3aa7e85c/w/fcb5131bee3c2f7da0dc39f6/e/9a60fc107ba1ab39dbb6ff48
Thanks for the reply Glen, when I looked closer at the extrude/remove on the "V" there was a small red line on the top right hand corner. I went back to the sketch, deleted 2 lines and redrew them and afterwards it extruded correctly.
