Where are these fields?
Ste_Wilson
Member Posts: 524 EDU
Good Morning,
I'm using the standard ISO A3 Template and that has some default fields which are good! I can get them automatically filled in by filling in the part properties.
There are however some which remain blank and I have no clue where to enter the information.
They are:
Drawing: Drawing part number
Drawing: Drawing revision
Drawing: Drawing approved by
Drawing: Drawing approved date
Any insight appreciated!
NeilCooke
Moderator, Onshape Employees Posts: 5,912
Right-click the drawing tab at the bottom and select properties. Not obvious I know.
Senior Director, Technical Services, EMEA3 -
eric_pesty
Member Posts: 2,410 PRO
You can also get there from the "workspace properties" in the hamburger menu (top left in the document) and expanding the "tree".
It's a quick way to get to all the properties of all the "things" in your document.2
No way!
I'm not sure I've ever looked there!
Perhaps some ui tweaking needed?
Cheers Eric. Again, not somewhere I've looked!
