Please help with assigning thickness to the surface; Thicken
mykola_kulishov
Member Posts: 12 ✭
Please help in applying Thicken to the surface, I need it to be 2-3 mm thick. I wonder what is wrong with me design that Thicken command does not work? Thanks
https://cad.onshape.com/documents/7a4f63352bafc5c20bc408d7/w/26832f78ae2ff333c7e32d9e/e/2334fe4ba093817cd63f6bf6?renderMode=0&uiState=66fb0383808fe10404970c02
The leaves on the bowl are degenerate surfaces. Two sides joint at zero degrees, and two join at 180. Both of those situations are not good for NURBS surfaces. I would recommend sweeping or revolving something and then projecting the final outline to get the shape you want.
Hello Simon, thanks for your advice. I did the mail bowl by revolving and Boolean subtraction, but the leaves going out i do not know how to make differently. I finally got to this stage, see the link, but I can not compose it in a single part. I am on a learning curve, but it is not easy to learn at my age :-)
https://cad.onshape.com/documents/61cccbf3e5c2fb4c325126d0/w/8184ad268031b38a762b40be/e/8b86458e712d52025ec95df1?renderMode=0&uiState=66fb3059808fe1040498402c
Hello Simon, I did it differently but still I can not Thicken this surface. What I am doing wrong. Is there anybody can help me ?
https://cad.onshape.com/documents/a8d1738fdb62afbeece12073/w/67a4671428ef7dd3f5bd2cdf/e/578c3b363217d3f708e8ea85?renderMode=0&uiState=66ff04db77d1c31474171d06
You need to fix this "wrinkle" in your suface:
Hello Eric, this is a transitional area between concave and convex shape. Any idea how to fix it? You can see from my file how i build the surface. So, what is wrong in my approach that produce this wrinkle?
