Importing templates
Hi,
I have an issue with templates created in Autocad as dwt files. When imported it shows white page without template details.
Can anyone advise how to fixed this issue?
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
My understanding is that, having saved as dxf or dwg from an external program, you then have to change the file extension to dwt by editing the filename before it can be imported for use as a template.5 -
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
1. Create template in (auto)cad and save as dwt
2. Import to Onshape
https://cad.onshape.com/help/#templates-custom.htm
//rami5
OR you can try with DWG format also
