Ability to only select outer or inner corners
peter_van_westen
Member Posts: 20 ✭
I frequently have have a case where I only want to fillet (or chamfer or whatever) the outer corners of something.
Now, I have to either select every corner I want one-by-one, which is really cumbersome.
Or drag a box to bulk select ALL corners, and then manually deselect all the corners I don't want, which is also really cumbersome.
So I would really like an option to either select only outer or inner corners with a modifier key.
Or some option in the fillet/chamfer/… window to have it only get applied on outer/inner/all corners.
To illustrate what I mean by just outer corners:
There's a custom feature which makes selections like this parametric.
https://forum.onshape.com/discussion/13958/new-custom-feature-selection-fillet
Thanks. Although it seems to not be very stable. Even when selecting a simple box shape, it will in some cases just error out and do nothing.
Thanks.
So: https://cad.onshape.com/documents/03d360e7ad4f6762d65fac6f/v/894decbb650e7c0077464295/e/7aa592d4ddb8c61a41a92b43
Created my own Selective Fillet feature:
https://cad.onshape.com/documents/c3e721ef16aa791c312234dd/w/8b51f061daef702bbe6f298b/e/0df6ae65cc181eeecedac441
