how can I change the scroll-wheel step value for numerical inputs?
joshtargo
joshtargo Member Posts: 628 EDU
change the value by increments of 1 is too coarse, is there a way to set a smaller step value when you use the scroll wheel to adjust a numerical input?
  • mahir
    mahir Member, Developers Posts: 1,324 ✭✭✭✭✭
    edited October 2024
    I'm not aware of any option/preference to change this. But you're free to log an enhancement request.
  • joshtargo
    what about some way to have + and - buttons on the input window so we can change a step value and use the buttons to go up or down one step per click?
  • mahir
  • joshtargo
    Yeah, but .1 is still too big sometimes. I need to figure out how to make buttons
  • Oliver_Couch
    Oliver_Couch Member Posts: 230 PRO
    Not certain, but possibly also changing the number of lines per scroll in your OS settings?
    S1mon Member Posts: 4,395 PRO
    It would be very nice if the scroll wheel increments were customizable beyond the standard 1/10 x, 1 x, and 10 x. Solidworks and Alias both have on-the-fly ability to tweak these values and pick from a list of options (I'm sure other tools do as well). Seems like it would be a good improvement request. I would vote for it.
  • joshtargo
    This would just make it do more steps per revolution, but would not change the step size.
    When tweaking curve control points or scale factors, 0.001 or 0.0001 can be necessary for fine control.
  • mahir
  • joshtargo
    As a workaround, I built this into a new FS I'm working on. Works well, and is easy (the script just multiplies the input numbers by different factors and adds them all up.
  • romeograham
    romeograham Member, csevp Posts: 770 PRO
    The stepping (with Ctrl and Shift modifiers) also works with the arrow keys. As long as your cursor is in the right place, it works like a charm to step up and down with the arrow keys rather than the mouse wheel.
    (Doesn't address your initial question, I know!)
  • Jim_Fife
    Jim_Fife Member Posts: 7
    Let's say I like to work in 64ths of an inch. I want to scroll the mouse wheel and change dimensions by .015625 inches. Or microns, or furlongs, or any increment I want. Does every stupid thing need an enhancement request to just get fixed right?
