New FeatureScript: Spring Creator
william_knoblauch
william_knoblauch Member Posts: 25 ✭✭
edited October 2024 in FeatureScript
Hi everyone,
I know I just posted the Plastic Thread FeatureScript about a week ago but I had an idea for a new script and came up with a working release version that I want to share with you all. The idea behind the new script is to make creating parameterized springs easy so you don’t have to do all the steps of making a spring from scratch. In attempting this, I found a huge amount of customization with springs, so there are a lot of inputs into the code, but even with all the customization right now extension and torsional springs are not possible directly from this script.
You can find the code here: Spring Creator
Features:
  • Four spring wire cross sections available (circular, ovate, square, rectangular)
  • Cylindrical and Conical Springs
  • Five end styles (no end coil, partial coil, machined partial coil, multi-coil, machined multi-coil)
  • Create mate connectors at each end for easy assembly
  • Three end type selections (blind, up to face, up to vertex)
To make a spring you have two initial inputs, a Point or Circular Edge:
AD_4nXfaA4XC1r5DP8CaL7nzuQucPe5ivbW5rFUBdWdiH6fYJ9TmD0W1sczbOkIuKf1foATp-FKV3fy4nq3bV1EFxV9HhGM7FeJ-sYEa1MeDu1gdug_-LQQn9Z4wq1fa3zBD1EchijrwivZxnSUzgn4holbumQjH?key=L-dZGWJFrW394A1uEWurmw
There are many options in the Spring Definition section including cylindrical vs conical springs, 4 different cross sections, different spring size definitions, number of coils, and adding mate connectors:
AD_4nXeUHOeL1ThPAA51mKKbXWVt6VQtsRRyuMsWL5kplyR8K_hxuVJMGXxULt24umgmcwhh8KXnqxw0JkPhKNjTSc94aJqa_sDGSY0ROLy75J1XmvQLORzGd36Zkl6yDhLEqVXuOGYoihtM2wqihqf1niHHhuG5?key=L-dZGWJFrW394A1uEWurmw
Next, you can change the end type and end style of the spring:
AD_4nXfneHyru8q9LddjII6ac0JBssqMIzZkBajQPt0sQcp49JUmT4axxUgdDpIizS-6NcJbq-I93AqvoRSL0gKVK_T6qVZEhirERty0hFknuTVYvnMHvCTWrKBdC5RwKG0C2lInpTuynXrnSkVplyNjpQx6R-Ol?key=L-dZGWJFrW394A1uEWurmw
The length of the spring is always maintained no matter the end style so there is no need to compensate for them.
Also because this script is parameterized you can create multiple configurations of the same spring to define each position of its motion:
AD_4nXcrCakzvWzBxpPLGNXCuxyIdeNnMvbA55_9gNkylgX_-4TpiAPZtZ-wnr1XGqW0kV8s5LuOoCTPYDHp73c3ZYYJYeSd0Wqw8hZRNEXptOaGKTu3dZpuodQCzipmJu3RytHjjJg3czKjDIpwfQimeAMbDYAV?key=L-dZGWJFrW394A1uEWurmw
The main goal of this FeatureScript is to remove the need to download and import parts from manufacturers. Here’s an example of how the tool can recreate a real spring (specifically spring 9573K11 from McMaster-Carr) :
AD_4nXdeRFHrYs6yR7qt22MhB--81aSyzBDhe8jze-aPYTFDawJ_Ey7tdZuGxGEZM4EihF3BuTYWls6dRgjlULlJEAJsKBD-i72JZi9hRlAu3xPpiQtiRFcXHFpc4gISfilKmESmAECI14kfgTWN1pYpdiRcIDE?key=L-dZGWJFrW394A1uEWurmw
Limitations:
  • Expansion springs are currently impossible to create in full with this code. You can get around this by using this code to make the base helix with a given profile and then adding hooks to the end.
  • None of the end styles have a smooth transition from the center helix to the end so there is a kink and a tangent line shows up.
Future Updates:
  • Expansion spring capability (probably a drop-down and then a list of end styles that can be selected specifically for expansion springs)
  • Torsional spring capability (maybe just taking in a starting and ending axis or a starting axis and angle between them and then extruding the coils out in a straight line)
  • Curved springs defined by an input path
  • New selections including axis and cylinder/cone
I hope this is a useful enough code for everyone and if you have any questions or suggestions for me, let me know in the comments and I’ll respond as quickly as possible. Also, let me know if the functionality of which axis is chosen as the axis of the spring is intuitive. I didn't do too much work to make it feel intuitive but it will override the selected axis with whichever axis is needed to complete the "up to" end types.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,902 PRO
    Nice!
    That looks awesome!
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,948 PRO
    I agree with Eric, Nice!
    This is really good. I've needed this from time to time.
  • Urs_Egger_REACT
    Urs_Egger_REACT Member Posts: 133 PRO
    That's a cool feature script! Thanks a lot.
    I do have a question regarding configurations. When I create different configurations each configuration gets another part number within the assembly. Any idea how to solve this if I want all the same springs in different configurations with the same part number?
  • eric_pesty
    Use the "exclude from properties" option on the configuration input.
    S1mon Member Posts: 4,583 PRO
    edited October 2024
    It would be a lot to ask, but I've often thought that something like Spring Calculator or Advanced Spring Design could be ported to Onshape. Perhaps PTC could acquire it or something like it?
  • jelte_steur_info
    jelte_steur_info Member Posts: 682 PRO
    very nice!
  • Urs_Egger_REACT
  • bl_trimontana
    bl_trimontana Member Posts: 8 ✭
    This is really great, thank you! Would it be possible to allow decimal numbers of coil turns? Often springs don't have integer numbers of turns I find. Thanks so much!
  • christian_vasquez494
    christian_vasquez494 Member Posts: 1 EDU
    Does anyone know how to, or if it is even possible, to animate a tension spring in Onshape? So far, I have managed to animate regular dynamic springs.
    Not in a straightforward way like in Creo or other tools which have true flexible components. People have hacked things to look like springs by making a bunch of half rings and mating them so that a spring assembly will look like it's flexing:
  • william_knoblauch
    @bl_trimontana It's definitely possible to add decimal coil turns, as I already do in the torsion springs, to achieve the desired angle, but it would take quite a big update to the code to make all the different end styles work. If you have a real spring you want to recreate with this script I would round the number of coils to a whole number. The main purpose of this script is to look nice in assemblies and drawings and to be configurable so you can see how it might move in real life. Is there a particular reason you want to be able to set a decimal number of coils other than to make the spring slightly more accurate to real life?
    @christian_vasquez494 I also looked into making it easier to animate the springs with the same method @S1mon referenced but it's a real hassle. I'm not planning on adding any feature to help with this because featurescript can only affect part studios and not assemblies. If you want to try animating a spring from my script you can generate the spring and then split it using the split feature to get all the different segments.
