some featurescript questions
joshtargojoshtargo Member Posts: 446 EDU
  1. How do I return a point where a plane intersects a curve?
  2. I'm doing multiple transforms on a curve, but some transforms are optional. I found it confusing to keep multiplying transforms to build one big final transform, so I want to split it up into steps. I referred to the result of the first transform with qcreatedby, but if some later transforms are optional, I won't necessarily know which function created the curve that needs to be transformed again. How do I refer to the object?
  3. How do I render a line for debug purposes if all I know is the origin and direction vector?
  4. can I render objects (planes, curves, lines, points) in bright orange to help the user visualize what the tool will do?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,912 image
    1. evDistance
    2. Go with the multiply option, it will be easier and faster
    3. addDebugLine
    4. addDebugEntities
  • MichaelPascoeMichaelPascoe Member Posts: 2,629 PRO
    edited October 2024 Answer ✓
    Like this @josh_targo
    const point1 = WORLD_ORIGIN;
    const direction = XY_PLANE.normal;
    const distance = 5 * inch;
    const point2 = direction * distance;
    addDebugLine(context, point1, point2, DebugColor.RED);
    Or you could simply just debug(context,line(point, direction), DebugColor.RED);
