compound angle sheet metal
MDesignMDesign Member Posts: 1,332 PRO
I'm trying to build some support brackets and I have a situation where I need to bend geometry around some compound angle. the mating surfaces are not perpendicular and the bracket legs are not perpindicular. Is this possible with the sheet metal tools? I haven't been able to figure it out. If not, how would you attack this to get the geometry as close as possible.
