future script help - beginner
rlbrkrlbrk Member Posts: 19
I asked Chat gpt to generate me a future script code for a gridfinity bin.
I tried to import the code and I got errors. I watched some tutorials on how to use it but I didn't manage to make it work.
how should I paste it correctly?
here is the code:
FeatureScript 1200;
import(path : "onshape/std/geometry.fs", version : "1200.0");
annotation { "Feature Type Name" : "Gridfinity Bin" }
export const gridfinityBin = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Width", "Default" : 42 * millimeter }
        definition.width is Length;
        annotation { "Name" : "Depth", "Default" : 42 * millimeter }
        definition.depth is Length;
        annotation { "Name" : "Height", "Default" : 7 * millimeter }
        definition.height is Length;
        annotation { "Name" : "Wall Thickness", "Default" : 2 * millimeter }
        definition.wallThickness is Length;
        // Main body of the bin
        var binProfile = rectangleSketch(context, id + "binProfile", {
            "cornerA" : vector(0, 0) * millimeter,
            "cornerB" : vector(definition.width, definition.depth)
        var binBody = extrude(context, id + "binBody", {
            "entities" : qSketchRegion(id + "binProfile"),
            "direction" : evOwnerSketchPlane(context, {
                "entity" : qSketchRegion(id + "binProfile")
            }).normal,
            "endBound" : BoundingType.BLIND,
            "endDepth" : definition.height
        // Hollow out the bin
        var hollowProfile = rectangleSketch(context, id + "hollowProfile", {
            "cornerA" : vector(definition.wallThickness, definition.wallThickness),
            "cornerB" : vector(definition.width - definition.wallThickness, definition.depth - definition.wallThickness)
        var hollowBody = extrude(context, id + "hollowBody", {
            "entities" : qSketchRegion(id + "hollowProfile"),
                "entity" : qSketchRegion(id + "hollowProfile")
            }).normal,
            "endDepth" : definition.height - definition.wallThickness,
            "operationType" : NewBodyOperationType.REMOVE
        // Create bottom cutouts
        var cutoutDiameter = 8 * millimeter;
        var cutoutRadius = cutoutDiameter / 2;
        var cutoutSpacing = 10 * millimeter;
        var cutoutPositions = [];
        for (var x = cutoutRadius; x < definition.width; x += cutoutSpacing) {
            for (var y = cutoutRadius; y < definition.depth; y += cutoutSpacing) {
                append(cutoutPositions, vector(x, y));
        for (var cutoutPosition in cutoutPositions) {
            var cutoutSketch = circleSketch(context, id + "cutoutSketch" + cutoutPosition, {
                "center" : cutoutPosition,
                "radius" : cutoutRadius
            var cutoutExtrude = extrude(context, id + "cutoutExtrude" + cutoutPosition, {
                "entities" : qSketchRegion(id + "cutoutSketch" + cutoutPosition),
                    "entity" : qSketchRegion(id + "cutoutSketch" + cutoutPosition)
                }).normal,
                "endDepth" : definition.wallThickness,
function rectangleSketch(context is Context, id is Id, corners is map)
    var sketch = newSketch(context, id, {
        "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
    skRectangle(sketch, "rectangle", {
        "cornerA" : corners.cornerA,
        "cornerB" : corners.cornerB
    skSolve(sketch);
    return sketch;
function circleSketch(context is Context, id is Id, parameters is map)
    skCircle(sketch, "circle", {
        "center" : parameters.center,
        "radius" : parameters.radius
    skSolve(sketch);
    return sketch;
  • Caden_ArmstrongCaden_Armstrong Member Posts: 300 PRO
    ChatGPT is not capable of creating a working featurescript. It only produces garbage.
    You'll have to learn how to write FeatureScript yourself. But Onshape has some great learning material to get you started:
    https://learn.onshape.com/courses/featurescript-fundamentals
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • Max_KlugeMax_Kluge Member Posts: 21 ✭✭
    As Caden said, ChatGPT is not capable of writing code properly and the OS Learning Center may help you out pretty good. As some kind of additional help: I made a Udemy course in JavaScript (you may also do TypeScript) to really learn the basics of codeing. Otherwise you will have a hard time understanding how FS really works.
  • MichaelPascoeMichaelPascoe Member Posts: 2,464 PRO
    Haven't tried it yet because it requires a subscription I believe, but C2I made a gpt app for FeatureScript. Not sure how well it works:
    https://forum.onshape.com/discussion/22785/introducing-gpt-c2i-featurescript-helper-for-chatgpt-testers-wanted..
    Definitely complete the course Caden mentioned: FeatureScript Fundamentals
    I've also been working on another FeatureScript course that has a different teaching style. It teaches on the fly so it may be easier to follow depending on your learning style: CADSharp FeatureScript Video Lessons
  • joshtargojoshtargo Member Posts: 360 EDU
    edited October 2024
    I've had fairly good luck with GPT to help me get something 90% of the way there, but of course the last 10% can be tricky. You can look at the standard library documentation https://cad.onshape.com/FsDoc/library.html but for non-programmers like me, it's very difficult to get a grasp on what it's telling you, and what it's leaving out.
    You can also use the many examples from the standard feature doc:
    https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/81869edac6224be29410b2a3Or use other people's featurescripts as a starting point and slowly modify them to do what you want.
    after that, I recommend re-writing the whole working script from scratch (using the existing script to learn from) so you can try to understand what each line is doing.
  • armandoRRarmandoRR Member Posts: 19 PRO
    I created a custom GPT through ChatGPT and fed in the entire standard features in text form and the API. It was a large improvement but still resulted in what everyone is saying, 90% of it is good, 10% isn't and you need 100% for the featurescript to run correctly.
    Philosophically, ChatGPT is not a replacement for learning a programming language.
    not a replacement, but 90% of the time, it's the patient, instantaneous teacher that I need.
