future script help - beginner
rlbrk
Member Posts: 31 ✭
I asked Chat gpt to generate me a future script code for a gridfinity bin.
I tried to import the code and I got errors. I watched some tutorials on how to use it but I didn't manage to make it work.
how should I paste it correctly?
here is the code:
here is the code:
FeatureScript 1200;
import(path : "onshape/std/geometry.fs", version : "1200.0");
annotation { "Feature Type Name" : "Gridfinity Bin" }
export const gridfinityBin = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Width", "Default" : 42 * millimeter }
definition.width is Length;
annotation { "Name" : "Depth", "Default" : 42 * millimeter }
definition.depth is Length;
annotation { "Name" : "Height", "Default" : 7 * millimeter }
definition.height is Length;
annotation { "Name" : "Wall Thickness", "Default" : 2 * millimeter }
definition.wallThickness is Length;
// Main body of the bin
var binProfile = rectangleSketch(context, id + "binProfile", {
"cornerA" : vector(0, 0) * millimeter,
"cornerB" : vector(definition.width, definition.depth)
var binBody = extrude(context, id + "binBody", {
"entities" : qSketchRegion(id + "binProfile"),
"direction" : evOwnerSketchPlane(context, {
"entity" : qSketchRegion(id + "binProfile")
}).normal,
"endBound" : BoundingType.BLIND,
"endDepth" : definition.height
// Hollow out the bin
var hollowProfile = rectangleSketch(context, id + "hollowProfile", {
"cornerA" : vector(definition.wallThickness, definition.wallThickness),
"cornerB" : vector(definition.width - definition.wallThickness, definition.depth - definition.wallThickness)
var hollowBody = extrude(context, id + "hollowBody", {
"entities" : qSketchRegion(id + "hollowProfile"),
"entity" : qSketchRegion(id + "hollowProfile")
}).normal,
"endDepth" : definition.height - definition.wallThickness,
"operationType" : NewBodyOperationType.REMOVE
// Create bottom cutouts
var cutoutDiameter = 8 * millimeter;
var cutoutRadius = cutoutDiameter / 2;
var cutoutSpacing = 10 * millimeter;
var cutoutPositions = [];
for (var x = cutoutRadius; x < definition.width; x += cutoutSpacing) {
for (var y = cutoutRadius; y < definition.depth; y += cutoutSpacing) {
append(cutoutPositions, vector(x, y));
for (var cutoutPosition in cutoutPositions) {
var cutoutSketch = circleSketch(context, id + "cutoutSketch" + cutoutPosition, {
"center" : cutoutPosition,
"radius" : cutoutRadius
var cutoutExtrude = extrude(context, id + "cutoutExtrude" + cutoutPosition, {
"entities" : qSketchRegion(id + "cutoutSketch" + cutoutPosition),
"entity" : qSketchRegion(id + "cutoutSketch" + cutoutPosition)
}).normal,
"endDepth" : definition.wallThickness,
function rectangleSketch(context is Context, id is Id, corners is map)
var sketch = newSketch(context, id, {
"sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
skRectangle(sketch, "rectangle", {
"cornerA" : corners.cornerA,
"cornerB" : corners.cornerB
skSolve(sketch);
return sketch;
function circleSketch(context is Context, id is Id, parameters is map)
skCircle(sketch, "circle", {
"center" : parameters.center,
"radius" : parameters.radius
skSolve(sketch);
return sketch;
You'll have to learn how to write FeatureScript yourself. But Onshape has some great learning material to get you started:
https://learn.onshape.com/courses/featurescript-fundamentals
As Caden said, ChatGPT is not capable of writing code properly and the OS Learning Center may help you out pretty good. As some kind of additional help: I made a Udemy course in JavaScript (you may also do TypeScript) to really learn the basics of codeing. Otherwise you will have a hard time understanding how FS really works.
Haven't tried it yet because it requires a subscription I believe, but C2I made a gpt app for FeatureScript. Not sure how well it works:
https://forum.onshape.com/discussion/22785/introducing-gpt-c2i-featurescript-helper-for-chatgpt-testers-wanted..
Definitely complete the course Caden mentioned: FeatureScript Fundamentals
I've also been working on another FeatureScript course that has a different teaching style. It teaches on the fly so it may be easier to follow depending on your learning style: CADSharp FeatureScript Video Lessons
RENDERCAD
I've had fairly good luck with GPT to help me get something 90% of the way there, but of course the last 10% can be tricky. You can look at the standard library documentation https://cad.onshape.com/FsDoc/library.html but for non-programmers like me, it's very difficult to get a grasp on what it's telling you, and what it's leaving out.
You can also use the many examples from the standard feature doc:
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/81869edac6224be29410b2a3Or use other people's featurescripts as a starting point and slowly modify them to do what you want.
after that, I recommend re-writing the whole working script from scratch (using the existing script to learn from) so you can try to understand what each line is doing.
I created a custom GPT through ChatGPT and fed in the entire standard features in text form and the API. It was a large improvement but still resulted in what everyone is saying, 90% of it is good, 10% isn't and you need 100% for the featurescript to run correctly.
Philosophically, ChatGPT is not a replacement for learning a programming language.
not a replacement, but 90% of the time, it's the patient, instantaneous teacher that I need.
