How can I make a flattenable square-to-round transition?
I see there is a lot on interest on sheet metal facilities, which I share. While it was very easy to draw a duct bend (Public file "Duct bend 200 mm ID 4 Sectors") I have not found a "clean" way to make a transition, which seems a very elementary piece. Individual sides can be produced by lofting and thickening surfaces, but they will not readily unite in one piece with the boolean command.
Incidentally, I flattened one sector of the bend -externally-, imported the dxf into a sketch and placed it on drawing page 2 by thickening the sketch... Just playing around to learn the program.
1) Bend sketch
2. Sweep profile
I apologize for the digression in my post, which made it confusing.
My question concerns a way to make a flatten-able square to round transition as shown. Lofting for a solid creates surfaces bent in two directions, which cannot be flattened. Lofting for surfaces works; but subsequent thickening creates solids which I could not manage to unite through the boolean command.
The sweep command creates the solid (duct bend) directly by sweeping through a path of straight lines.
However, I am also trying to find the workaround method to achieve the geometry what you have shown. I will post it once I find any method.
Thanks
Lofting between two arches after replacing the vertex of the cone by an small arch, say 0.01 mm diameter, does produce a surface which thickens to a solid that joins the adjacent geometry after thickening. But it's kind of a "dirty trick".
This is perhaps an indication that lofting should be extended to be able to produce this type of seemingly simple geometry.
I am interested to to see if you find other alternatives.
