Aligned measurement issues
anthony_dean
Member Posts: 8 ✭
I am having trouble creating dimensions between points on a drawing that don’t align horizontally or vertically. This may be referred to as an Aligned measurement.
At the page:
it says: “Dragging the text around during preview allows for the text to move outside of the extension lines, and also switch between horizontal, vertical, and aligned measurement modes: Dragging the text away in a direction perpendicular to a line through the two chosen snap points creates a dimension line parallel to the two chosen snap points”
However, I find this rarely works. With the dimension tool active I click on two diagonal points and Onshape instantly wants to create a horizontal or vertical dimension between the points regardless of where I drag the dimension text. The pull-down options on the Dimension tool include one for 2 point linear dimension, however having this option active still results in the ability to make only horizontal or vertical dimensions. After several minutes of canceling and reactivating the Dimension tool I can sometimes get a point to point aligned dimension between two diagonal points - but this problem is very frustrating.
Oliver_Couch
Member Posts: 230 PRO
You need to drag it further away. Try zooming out.
There's an improvement request logged to make drawing dimensions work the same as sketch dimensions.
1
The point to point dimension tool "should" have a third selection pick, (pick a line, after picking the two points) that forces the dimension to "align" to that particular line, or other existing geometry.
Re: "drag it further away. Try zooming out." - Yes, this does work sometimes - Thank you.
This is still a suboptimal tool for aligned dimensions, so I await the rumored improvement coming.
I agree!
