How would I go about creating mates for this mechanism?
Hi! I am trying to simulate this mechanical movement in Onshape for a personal project:
I made some distance until I attempted simulating both the Catch → Notch Wheel movement, as well as the Slotted Cam Movement. Is it possible to replicate this in Onshape? If so, what would be a good away of doing so? Here is my document: https://cad.onshape.com/documents/9c8410496ee2289cc9d38200/w/071d36a93e8acd660ba27eb0/e/53751d69c720a4aa0c38084f
  • jelte_steur814jelte_steur814 Member Posts: 485 PRO
    perhaps if you put a tiny fillet on the corners of the notches on the notch wheel, you could put a tangent mate on that.
    a tangent mate would also be the way to go for the slot.
  • peter_story327peter_story327 Member Posts: 4
    @jelte_steur814 Would it be possible if you could specify where in each part a tangent mate would work? I did try to do a tangent mate in the slot cam a few days ago but struggled quite a bit
    on one of the faces of the slot, and the pin. if that doesn't work, you could add a sketch for the center of the slot to your assembly and tangent mate it to the centre of the pin.
    and another one on for the pin onto the cog faces when they have fillets
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 153
    @peter_story327
    You should be able to recreated the slotted CAM as well as the notch wheel with a guide curve and tangent mate.
    Have a look if this example helps you: https://cad.onshape.com/documents/4d0e29b530b089b951a94da5/w/3fb6ab635d027588aeddc5f2/e/2487cc4fb144652d2a49260d
