Cant make a fillet
chimper_chimper_ Member Posts: 2
Hey! im making a custom case for the RK84 and one of my fillets wont work i got muliple of these to work ande this one doesnt for some reason
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 258
    @chimper_ Without having the model to test it is difficult to diagnose. Please share your document as public and share the link here.
  • rick_randallrick_randall Member Posts: 394 ✭✭✭
    edited October 2024
    • 1) Try using the rollback bar, and/or reorder your fillets - try different combinations, sometimes this will make a difference.
    • 2) As a diagnostic tool - change to a smaller radius to check if there is a non-manifold body issue.
    I've run into this before myself - with a little tinkering you should be able to solve this.
