Onshape on premises with Solidworks
We are already on board with solid works 2014 upgradeable to 2015. We are a small shop with only three seats.
PART 1
There is a situation where we want
PART 2
We want to be able to give out our cad models in a restricted format i.e. with only one or two non-constraints i.e. they will be able to modify just one or two changes and use in their design. How can we do this with Onshape??
PART 1
- our models to be looked over,
- Downloaded and fit into our customer assembly.
- Modified by them in solid works and uploaded back to on shape
- We can download at our end and start working on it.
PART 2
1
If you copy the workspace, you will have two copies of your onshape document. Then export the copy, your customer fits it into assembly making any modifications. You then upload this back to onshape. You then compare the two documents and copy your customers modifications onto your original copy (this original still has your history)
Again for Part2 if you save as a stp file reimport it and then add your one or two constraints that they are allowed to modify,I think this would work.
