What is the secret behind adding a link in a comment?
rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
Since the update of this forum, my links (and not only mine) are displayed as text in the comments. Even when I define them as links.
I am wondering because it is clearly possible to insert a link as a link. There are examples, but it is also clear that many users are struggling with me on this issue because many links in comments are plain text.
What am I doing wrong?
  • S1monS1mon Member Posts: 4,088 PRO
    edited October 2024 Answer ✓
    Defining a link.
    I find that I need to pause for a fraction of a second when hitting enter/return in the link definition window. If it doesn't turn the text blue in the preview, try again. Sometimes it will add the link at the beginning of the post even if it should be somewhere else. It's definitely flakey, but it does work.
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    OK guys, thanks a lot. I now know what was going on. I was already using S1mons method, but I never changed the "text to display". In this case, as you can see in my post above, the link is broken. If I change the text, it works. Strange behaviour.
    Thank you all for your help!
