Any way to feed additional info into the Manipulator Change Function?
joshtargo
Member Posts: 454 EDU
I want to use a Real from definition to adjust the sensitivity of the perceived manipulator movement.
any way to do this?
S1mon
Member Posts: 3,768 PRO
Look at the code for Bridging curve and the older magnitude type (not control point) of manipulation. I’m pretty sure there’s a sensitivity multiplier in use there.
1
it works ( i didn't use bridge code, but somehow it helped me find where to look)
